I am using Zbrush 3.5 R3 Full Licence and attempted to make use of the new UVMaster Plugin. As the directions instructed the file was unzipped and the UVMaster_1.0.zsc was installed to C:\Program Files\Pixologic\ZBrush 3.5 R3\ZStartup\ZPlugs. Also moved the folder UVMasterData_1.0 there and the plugin refuses to load or show up in the menu. Any feedback?
Figured out. Following the instructions to load the plug-in is just slightly misleading but to correctly install this one you actually need to pull the folder called UVMasterData_1.0 out of the file called UVMaster_win_1.0 and install that and the file UVMaster_1.0.zsc in the zplugs folder. If you leave it in the folder that unzipping creates it will not work.
I was a newbie at installing plug-ins just thought I’d share this with other newbies to avoid possible confusion over the install.
hi,
yesterday i have done the same mistake.
read the manual watchfull before copy the foöder
