UV Master wiping control maps (frequently)
I’ve looked through the forums and the web and I cannot figure out why I’m having a problem with UV Master constantly wiping the “Protect”, “Attract” and “Density” maps I paint. It becomes evident that it’s dropping them when I switch to another control paint mode and then back. It will appear blank white again with all the paint gone (I’m not hitting the “Erase” button). But I know it is not losing it when I switch because often when I hit “Unwrap” it behaves as though I do not have any control maps painted. It seems to occur more frequently if I used Ctrl+Z and also after I use “Unwrap” button.
I am using the UV Master that came pre-installed with ZBRush 4R6 P2. I have way more RAM than ZBrush knows how to use because it’s only 32-bit (WTH?). I have well over 300GB of free space on my hard drive. Disk fragmentation is at 0% and there are not disk errors. I’ve reinstalled ZBrush (and wiped all files) several times. With no custom UI or addons. I tried even running ZBrush as admin and it still wipes the control maps. I’d appreciate any suggestions on what might fix this bug.
