I need some help with the new uvmaster tools.
I’ve unwrapped the zbrush standard models like the rhino etc …
succesfully, but when I try the tools on my own model, a octopus,
I’m getting the same error. It will unfold ok, but when flatten the
model to check the uv’s, my model is way oversized, as not visible
on the grid. If I try to rescale the flattened model to fit within the
grid or unify and then try to unflatten, zbrush crashes, each time.
So this is definitely repeatable. Any one have the same problem or
have a work-around.
thanks
e1
