UV Master Problems
Here I go again.
I searched the forums for UV master, and all I found was topics with the word MASTER in it.
I have a very simple object, 52 total points. When I go to tell UV master where I want a general area for my seems using Control Painting and Attract, it ignores them completely. Straight up ignores them My entire model is orange after I paint the seems, unwrap, then check the flatten.
Now. I had the same thing happen to me before, on a more dense model and was never able to figure out what I was doing wrong.
can you post up pics, and/or the model for trouble shooting/testing?
How do I upload the tool for you to look at?
WHen I use the attachments, it says invalid file. Should I load an .OBJ?
PS. I went back into Max and hand unwrapped the model. But I would like to use Zbrushes features, after all it is why I got it haha.
dropbox, google drive, skydrive, mega, etc
I tried .OBJ. Still wont let me. Ill get some pictures soon.
Zip the file (something.zip)so it’s less than 500 kb. More info in your ZBrush/Documentation folder.
I have no idea what the heck is going on. I went to get some pictures, had to redo the seam creation, now it is working fine. Ill post back when it goes wrong again.
I went back into the original file, and painted some protect/attract areas.
This is what I got after flattening
I then went into the pre UVed mesh from max, made different painting marks then what I pre set up, flattened, and it worked properly…
