UV master problem
Hi guys…I have a huge problem…my model is too big in poly number to unwrap.
So i try to decimate and/or zremsh …even after that it says: not enough memory …split model in sub tools to reduce polycount…
can I avoid this ? How Do i handle high poly objects to export them later in 3ds max with UV ???
if i split it…will the seems be visible later in keyshot or 3d max ???
thanks :slight_smile:
Why not make the UVs before you delete the lower subdivisions?
Splitting the object into subtools for rendering in Keyshot means you will have to import them individually, unless you are using the Goz plugin which currently only works on Keyshot 4. It’s promised for Keyshot 5 soon.
what do you mean you don’t have enough memory to unwrap the object after using Zremesher?
What is the polycount of your lowest subD level of your Zremeshed object?
Can you post up pictures showing your model?
What are the specs of your system, os, ram, etc?
to distiller: hi thanks :)…but I can’t find the Goz plugin…can U help in this ??? I have keyshot 4 !
to beta-chanel:
hi … here I send U the info…let me know what U think…
it happens that sometimes I can create UV with UVMASTER…but than the PROJECTION of the high poly infos on the low one will freeze all…and will again not work…
So youre saying you error out trying to use project all?
yes… sometimes also zremsesher gives memory problems…but now that I got the low poly ( after many tries ) …I can’t project all …
what do U think about ? and how is my pc ???
It’s in beta testing and you have to ask for it over on the Keyshot forum. Usually a PM to Thomas Teger is all it takes.
how many points is your highpoly for both objects?
What are your preference.mem settings?
Your pc should be fine for working in Zbrush and doing what you’re trying to do.
hi, my preference.mem is 3000
I uploaded above the image with poly number…
do u have suggestions to make the software running faster/better like memory changes ec or other tricks ?
Can somebody send me the z plug in for keyshot since it’s not anymore downladable ( I asked luxion )…it should be free,…so if U can send me let me know :slight_smile:
thanks guys
In “Preferences > Mem”, set your “Compact Mem” to 4096 then “Store Config” (Ctrl+Shift+I).
thanks for the tip :slight_smile: I will try
bye
Mario
