my UV Master plugin isn’t showing up in the Zplugin Tab.
im running 64bit win7
You have not installed it correctly. Read the pdf that comes with the download. Don’t just unzip into the zplugs folder, unzip then move the correct files to the correct locations.http://www.zbrushcentral.com/showthread.php?t=82783
Richard
Thanks, this is what happened.
It’s installed incorrectly. The UVMaster_1.0.zsc is installed right,
but you didn’t move the data folder out of the UVMaster folder.
So the data is buried too deeply for ZBrush to see it.
