I’m having a problem with UV Master. I go through the whole process, create a clone, paint protect/attract, unwrap, copy UV’s. I then switch back to the original sclupt and attempt to paste UV’s. At this point, Zbrush seems to be working…, I get the small arrow with a Z next to it but nothing else happens. I waited 30 minutes the other day without any success.
I tested this on a computer much more powerful than my own and got the same results. I also attempted to use a lower resolution subdivision, deleting the higher subdivisions… no change. I’m not sure what’s going on. Has anyone had a similar experience and/or might know what’s going on? Any help would be appreciated.
I know there is a way to unwrap the model in 3DS Max and project it onto my Zbrush model but I haven’t found a tutorial explaining this process. As an alternative, if anyone knows of a good tutorial explaining how to do this, that would work too.
Thanks in advance,
John Anderson
UV Map > Delete UV
