uv-master not found
uv-master dosn’t run on my zbrush instasllation with win xp64.
i’ have copied the files “UVMaster_1.0.zsc” into “D:\Program Files (x86)\Pixologic\ZBrush 3.5 R3\ZStartup\ZPlugs”
and the uv-master folder is copied to the same path.
when i run zbrush 3.5_r3 i can’t find the plug in the plugin menu.
are you know problems with the plugin?
i can copy from here to there and otherwise, but dosn’t helps.
hope you can tell me whats wrong:)
thx for reading.
greetings jovomo
Did you put the UVMaster folder into Zplugs or the UVMasterData folder? It should have been the latter.
If you meant the data folder, have you tried unzipping and reinstalling? That has resolved most of the odd cases where a proper installation didn’t show up.
mine is doing the same. it won’t show up in the plugins
I have the same problem.
The only thing I could think of is checking the version. Is 3.5r3 different than 3.5 and I missed it?
