Whenever i try using the newly released unwrap plugin UV Master, Zbrush gives me an error messag wich states the following “an error occured during the process” wich i guess it means the process of unwrapping cause i only get this error when i press the unwrap butten…
info…
Windows XP 32bit
Zbrush 3.5 r3
I tried reinstalling zbrush, i checked if i put the plugin in the correct folder (i did) and i can;t find anything on zbrush central… i;m also getting the following error whenever i try to import a .OBJ model in my tool.
“INTERNAL ERROR .\System.cpp Line: 250”
