UV master changes object scale
I’m having an issue with UV master. Whenever I run the unwrap feature my mesh is scaled incorrectly when it is brought back into max. importing and exporting using both GoZ and standard OBJ export works perfectly, but once UV Master is used the scale is changed. I have check and reset export settings in the tool menu and that does not fix the issue.
