I made UVs with UV master and its ok, only problem is all polygons are break appart, not welded together. I have to go to other 3D program and fix that. How I can do this right in ZBrush so it will export fine?
Thank you.
Thank you.
“Tool > Geometry > Modify Topology > WeldPoints”
I mean in UV map. This function weld vertexes on object, right? I need to weld points in UV map.
Did you weld the points before you made a UV map in UV Master?
Object is fine, I can sculpt without any problem. But polygons in UV are separated.
