Hello everyone! i’ve been lurking the web to get some help but nothing seemed to work out…
I’ve 3 subtools in my project (appended in a single tool) each one has it own UV map (though uv master) and the texture was done in ZappLink and Photoshop.
My problem is that i need to use the model in another software to tweak it etc but it doesn’t support multiple texture objects so i’ve to have a single UV map.
So here’s my question:is there any way to get all the subtools into a single one with the same uvs since otherwise i’ll to texture it all again? i’ve tried uv master,multimap exporter but nothing seemed to work,thanks in advance
edit:i just found out that UV maps are properly viewed in zbrush but not in others 3d programs (i created them with uv master if that matters and i export the tool as .obj)
