UV map border does not work.
In ZBrush R8 ---- using the Multi Map Exporter.
Increasing the uv map border does not work. I’ve tried both the multi map exporter slider, and the uv map slider.
Does not matter, each render does -not- increase the uv map border.
(not a good problem to have, as your model has a higher chance of showing bad seams this way).
PLEASE FIX.
It’s working for me. What OS are you on, and what map size are you using?Border0.jpgBorder16.jpg
