I’ve done a search but can’t find an answer to my particular query. I have two tablets, a Cintiq and an Intuo3, both plugged in at the same time.
The problem I have is that Zbrush seems to sense the Intuos ok, but does some weird behaviour on the Cintiq (ie some brushes are reversed, push instead of pull, or just don’t behave correctly).
So, will Zbrush only work with one tablet correctly? If I unplug the intuos before loading the program, then plug it back in once Zbrush is running, the effect is reversed. Then the Cintiq works fine, but the Intuos behaves oddly.
This is the only program I have that doesn’t work with multiple tablets, although I know this isn’t the only program in the world not to. Just seems weird as it is a professional app. Is it just me, or this is just how it is?
