Ihave just today made this model, and I used the projection master to give it a paintjob. But it has given me a few questions. When you use projection master to paint a model, can you save the information… as far as I can figure, once you ‘pick up’ the model again all that work is lost? and also, once you have rendered an image, how do you save a copy? I see no options in the render menu for this, and the document only saves as a zbr. file. Is there no way to save out a jpg or similar to open up in 2d
image editing software
For painting with color, Projection Master requires a texture (with UVs) to be applied, or Polypainting mode to be active.
If a texture is applied, that information is saved to the texture. If polypainting is active, that color info is saved as polypaint, and can later be converted to a texture if UVs are applied.
You can save your “render scene” (minus any active tools) by saving a “document” in the Document menu. You can export an image in a number of formats via the “export” option in the same menu.
This is all fairly basic information easily available in the Zbrush documentation.
thanks scott. I did check through the render section of the documentation, but I couldnt see anything there. I was interested in working through the tutorials at the bottom of the documentation page, but the one I was interested began witha file which I have to download from the ‘resources folder’? Do you know where I can find this?
It would help if you could point me at a specific item or tutorial, but it is most likely one of the default models that comes with Zbrush (accessible in 3.5 via the Lightbox menu at startup).
The tutorial is
Tutorial: Modeling a Telephone:Edge loop and low-resolution mesh modeling, Projection and Normal maps, edge crisping, (a different way of maintaining edge sharpness).
I use zbrush 3.1.
