If you apply a micromesh form to a polygon strand created by fibermesh it will stretch the micromesh form along the length of that strand’s polygons. If you then export the strand created by fibermesh out then reimport it back in the default behavior of the micromesh reverts back to creating a micromesh created per polygon.
Is there a way ( as with the fibermesh ) to tag a row of polygons derived from a standard mesh (to act as a method of bending/ stretching a form to a specified shape ) rather than the default behavior of inserting a mesh per polygon?
The same too for nanomesh - can a nanomesh using Zmodeller be inserted to stretch across multiple selected polys rather than per poly?
Many thanks
