Using Material Modifiers in 3.5 R3?
Hi there,
I can make some basic materials but I am having trouble using the more advanced features. For example how do you utilize S2 or the channels?
I looked in documentation and it does not specifically cover this area. Or if it does it is from an earlier version that does not use the same buttons or terms.
How do I load material texture 2? Also sometimes I see an image of two spheres close together with one I think is supposed to be the cavity effect with the transition going between the two. Are both of those spheres on the same actual image? Or is one in mat tex 2?
Any help would be appreciated. :slight_smile:
