Using Alphas in Noisemaker and Offset
Is there a trick to get the “Offset” and “Angle” tools to work if you are using an Alpha in Noise Maker? These tools work fine if you are using 1 of the plugins, but don’t have any effect when just using a custom alpha. Is it supposed to be like this? Would be handy if it worked. Or is it just I can’t get them to work.
Thanks,
Sam.
Those sliders only work with procedural noise, not with custom alphas. You’ll have to rotate the UVs or the alpha itself for now.
Ok, thanks for the confirmation. I can load them into lightbox & use spotlight, doesn’t quite do as nice a job as easily though!
