Just would like to change several objects into a modeling sphere or Cube and then sculpt on them to make Morphs…Has to have same Poly count when Macro’d…
A picture is easier than words.
Click on the Qmesh initialize primitive of your choice.
Really…Why did I not see this before…?
Thanks will try out…
Does what it says BUT…
It doesnt have the same poly count when Initilized…
I played with the sliders but to get an actual Poly count was horrendous…
We need perfect precision when making morphs or they wont work…
So we need an input that would give the option of how many polys the initialize does…
Simply having the same poly count isn’t enough to get good morphs - they’ll basically be a mess because there won’t be any correspondence between the point positions. If you want to have a sphere then you’ll need to start from a sphere and sculpt the object. You could then return to the sphere to sculpt the morphs.
I installed the SeamlessTexture script but the texture it exports does not exactly tile seamlessly: https://i.gyazo.com/c4c6de207184eb767a262104745cc85f.png
What should I do ?
Hi bergamasque,
Can you share the project (.ZPR) or document (.ZBR) file with me? I don’t know why you should be having problems, the plugin works fine for me.
Hi Marcus,
I just discovered the BrushToggle macro script, it work nicely.
Is there a way to make several toggles that I could use with different hotkeys ?
I tried to copy the script and make it create a “BrushToggleData_2.zvr”, well, didn’t work haha at least I tried !
Now I just have 2 hotkeys for the same toggle, pretty useless xD
I would like to use other toggles for say, different Zmodeler brushes, different clays, different polish… you see ! That would be great
Hoping you see this message !
moved to 4r6 thread
Hi Marcus,
I’m just new here and looking for this copy-paste tool but I can’t see any download link. Can you help me with this or what should I do to get the link. Thank you very much!
Is it possible to get this Numpad Pop-up Menu Plugin somewhere? there seems to be no download links, and the “this thread” link is broken.
