Use Posable Symmetry in ZBrush 4
Please help about the following:
the enclosed model was made with ZSpheres, worked with Symmetry active, Subdivision=7, centerline OK.
My ZBrush 4 has Compact Mem=1500 (out of 2 GB of RAM) and Posable Symmetry works perfectly on the default DemoSoldier.ZPR .
The head has been slightly rotated with Transpose Tool, and Use Posable Symmetry doesn’t work with it: the symmetry is found only at a very low percentage, and ZBrush (and the whole computer) paralizes for about 10 minutes.
I’m becoming very sad with that… Thank you for any help!
Eduardo
Could you provide the file to test with?
Hello aurick,
thank you for your prompt answer!
I’m enclosing the address to the file of my model:
http://www.fileden.com/files/2010/4/9/2822706//Model_27_test1.ZTL
not really a work, more an exercise when studying this wonderful program.
There are sub-tools also, maybe they are somehow responsible…
My best regards,
Eduardo
