Unusual problem.
Hello. I imported an OBJ from max, started sculpting, just one subdivision so far. I save the tool and quit, then open it again, and everything is fine. But when I try to subdivide again I get an error saying something about being having to be on the lowest level of subdivision to subdivide again. I go to the first level, try to subdivide, and get told I can’t because there is already a second layer of subdivision, which I can understand. But why can’t I subdivide again on the second subdivision? I tried deleting the lowest level, and then the subdivision works, but it’s not smoothing, instead it tesselates rather than subdivides (the polygon count goes up but it retains its faceted look)
What’s going on? :lol:
sounds like you have a mask on your model when you try to subdivide.
masking>clear mask
then try to subD again at the highest level (lvl2)
should work.
goodluck
