UNIFIED SKIN
After you’re finished with “Initialize”, make it a PolyMesh3D before you “Make Unified Skin”.
If you open the default cube scene(.zpr) from LightBox and reduce the subdivision level to 1 and then perform reconstruct lower you can get down to 6 faces. If you start with the cube in the tool menu you can go into the initialize panel and set some options there before making PolyMesh 3D. Hope that helps.
I have tried this and I get the same results. The only thing that works is going to project and selecting the cube, but its a lot of work. I wonder why pixologic changed the feature
http://docs.pixologic.com/reference-guide/tool/zsphere/unified-skin/
Excerpted from there
Make Unified Skin
The Make Unified Skin button creates a new mesh by stretching a ‘skin’ around this object. The attributes of the skin are determined by the Skin Resolution, Skin Density, and Skin Smoothness items.
What are you trying to do?
thank you for your help its working now
