Undoing spotlight adjustments...?
I’ve been playing with this for a while and it struck me today that I can’t seem to undo/redo the little adjustments of rotating/scaling/opacity. I also noticed that spotlight has its own undo/redo under the Edit menu. So feeling fancy I assigned hotkeys to both tool and spotlight undo/redos and it didn’t seem to change anything.
What I do get when using Spotlight undo is that it hops to the other texture I have open and assigns it the rotation/scale/opacity value etc that I had tweaked on texture A. It only seems to want to undo/redo the deletion/addition of new textures into Spotlight, boooo!
To the point: is this the actual intended behaviour for spotlight undo/redo?
Thanks for your time!
