Hi, I’ve been having trouble assigning a new hotkey to my undo buttons. I assign them and they work once and then return to the defaults. I’ve visited these threads along with a few others and none have solved the problem.
Undo hotkey, cntrl Z, stops working repeatedly
Undo hotkey change does not work, … ctrl+z too tricky. How to resolve?[Answered]
4R2b Cmd+Z Undo � not working and can’t assign.
My goal is to assign the Tool undo/redo buttons as such:
Undo: Left arrow button
Redo: Right arrow button
As a side not, something else that I think is worth mentioning is that some hotkeys I’ve assigned haven’t had this problem and they show up in the StartupHotkeys.TXT. However, there are other assignments that work but don’t show up in the txt.
For example, I’ve assigned tool rotate to 7 on the numberpad, move to 8 on the numberpad, and scale to 9 on the numberpad.
Here is what the text file says:
//ZBrush Hotkeys
[BRUSH:MORE ITEMS,98] // B
[BRUSH:STANDARD,5447796] // Popup+T
[BRUSH:SMOOTH STRONGER,5447795] // Popup+S
[BRUSH:MOVE ELASTIC,5054565] // Popup+E
[BRUSH:MPOLISH,7151728] // Popup+P
[BRUSH:CLIPCURVE,4399203] // Popup+C
[BRUSH:CLAYLINE,4399212] // Popup+L
[TRANSFORM: PF,220] // �
[TOOL:GEOMETRY:LOWER RES,45] // -
[TOOL:GEOMETRY:HIGHER RES,43] // +
[TOOL:SAVE AS,48] // 0
[ZPLUGIN:MISC UTILITIES :BRUSH>>,221] // ]
[ZPLUGIN:MISC UTILITIES :<<BRUSH,219] // [
I don’t see anything referring to the numberpad hotkeys in there. Any explanation for why it’s doing this? If not, no worries: what’s important is that they work. My real priority is to get those undo/redo buttons working.
Thanks very much in advance.
