undo question
<!–[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]–><!–[if gte mso 9]><xml> <w:LatentStyles DefLockedState=“false” LatentStyleCount=“156”> </w:LatentStyles> </xml><![endif]–><!–[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:“טבלה רגילה”; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:“Times New Roman”; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]–> hi everyone. I just wanted to ask if there is any way that I can undo\redo a navigation action like rotate\scale\move and the “frame” action ?
Every few minutes of sculpturing my tool size is changing to a “frame” size and when i use ctrl+z it only undo my last sculpturing and doesn’t bring back the previous view.
how can i undo or go back to previous view?
Undoing a navigation operation is not possible to my knowledge.
In response to your framing problem: if you hold ALT and tap outside the model it will frame the tool. Maybe you are accidentally tapping lightly outside the tool while navigate?
lyou can store the view in the timeline or you can go to documents>zapplinkproperties>cust1 to store a custom view. whenever you change the view just click on cust1 to go back to that view
Yeah, Zapplink is what you’re looking for. Once you find a camera view you like that you’d want to use for your final render, just open Zapplink and store the view. If you find that you want to do a character or pose sheet or something, you can store multiple views at the same time. The best part is that even if you double your document size later for bigger/better render quality, your views are still stored :slight_smile:
Thanks guys ! :slight_smile:
