Hey guys!
Short question:
Since a while ago, I’m only allowed to undo for 4 times, while that used to be a lot more… do any of you guys know how I should change that??
Thanks in advance!
Hey guys!
Short question:
Thanks in advance!
Oh and by the way, I do have enough free space on my computer!
Up your undo levels in the preferences.
Careful though. Zbrush will become unstable at high subdivision levels with higher undo levels.
ZBrush Undo slider in Preferences >> Mem is the -minimum- number of undos!
By default, at 4, it means that ZBrush will keep at least 4 undos, but if it can store more undo levels, depending on the available RAM, it will store a lot more.
Most of the time, you don’t have to change this setting.
Personally, I put this level at 2, no more, then do a Store config.
Hey guys thanks for the replies!
Usually I had the undo’s at 15, but like I said it suddenly changed to 4, which is not enough (been using store morph target instead)
But it’s fixed now thanks a lot!
