undo hotkey reasignement
Hello Folks,
For a reason I don’t really understand, reassigning a hotkey for any functions works fine except for UNDO. I’ve been trying for hours but sadly failed.
First, I tried to assign a hotkey (CTRL+ALT click on the windowID). The new assignement appears on the startupHotkeys.txt
[EDIT:TOOL:UNDO 11,625] // Ctrl+Q
It works fine but only for the eleventh undo!
By the way, I changed UNDO 11 with UNDO just to experiment but it’s not working anymore.
Is it possible to assign a hotkey to “every” UNDO?
Cheers
bruce
It should work if you edit the StartupHotkeys.txt file to remove the undo number:
[EDIT:TOOL:UNDO,625] // Ctrl+Q
Make sure you are editing the file in the Users\Public\Documents\ZBrushData\ZStartup\Hotkeys folder.
The default assignments are shown at the bottom of this page:
http://docs.pixologic.com/user-guide/keyboard-shortcuts/defaulthotkeys-file/
Hi Marcus,
Thank you very much, It works like a charm.
Bruce
