All of a sudden I get one undo.
Hello @jimmylegs ,
Most common reason: A large file or dense mesh you are attempting to work with has caused ZBrush to exceed the limits set in Preferences> Undo History, and it has purged undo history to free up room. Either change the settings in that menu, or reduce the size of your mesh/file.
Other issues are possible. If this is something that happens with any file you attempt to work with and not just a specific file, there may be a general issue on your system. In this case, please contact ZBrush support. Technical Support for ZBrush is not provided over the community Usage Questions forums.
Thank you!
You might also want to try CompactNow. I placed a button on my UI ( /preferences/mem/CompactNow ) that solves the undo-history issue for a while.
My m1 Mac has very little memory and often get warnings about losing undo history. Especially when using sculptris pro. CompactNow seems to reset it or something.
Thanks I will check it out. I was baffled at first because the mesh I am working is pretty small but I forgot I have a skeleton and a ecroche model in the scene for reference.
