Undesirable deformation of cube while moving it
Last week I encountered this issue. I add a cube via append in the subtool palette. When I try to move it, it begins to stretch. Even turning off the symmetry doesn’t help. Unfortunately I don’t have the file right now but I recorded myself facing this issue.
It has happened with my multiple times but very less often. I don’t know what exactly triggers this. It seems as if I press some key that toggles this mode on.
It does not happen when I start a new document from scratch.
New feature in ZB2022 adds Focal Shift functionality to the Gizmo. Set Focal Shift to -100 for uniform translation, scaling, rotation. Anything else will localize the Gizmo action.
(2) ZBrush 2022 - Gizmo Focal Shift Falloff! Manipulate multiple subtools with just the gizmo! - YouTube
Thank you so much! All solved now! Really appreciate. This stretching trouble was playing in my head for so long.
