I get this message now every time i try to crank up the mem preferences. i’ve 3gb ram and i need to set it to the polygons of at least 10mio because my model is around that amount. i also dont exceed over 2400mb in the mem prefs.
then i tested many things in order to evaluate the problem. i found out that by removing the UIStandard.cfg file the error wouldnt appear again but my problem is that without the ui file the zb3 ui is blank. even when i loaded other uis the problem still occured. so i’m not sure if it’s some kind of ui issue or not that causes this virtual memory error.
even if i set it to only 6mio instead of the default i still get the error.
its really annoying. i cant do anything because i need to work in subd-level 6 to finish the fine detail.
any suggestions?
