Keep getting this when trying to save; virtual memory custom set to 25000 MB.
Intel Core 2 Duo Extreme Q6850 @3.00 GHz (quad core)
8GB ram
Windows 7 Ultimate
Tons of HDD space.
8GB ram
Windows 7 Ultimate
Tons of HDD space.
Which version of ZBrush are you using? As per forum policy stated here, could you show a screenshot of the entire interface without the top cut off.
Ooops…4R4
i am getting the same proble here,
im on Zbrush 4R4 P2
any word on whats going on and how to fix this?
I believe it stems from merging subtools without having uv’s assigned to them.
The error you are getting about Unable to Offline a Memory is a known issue that we are currently working on. It is caused by the UV button not being turned on when a MergeDown is done. The way to avoid this error is to make sure that you have turned on the UV button right below MergeVisible before completing the MergeDown.
Sincerely,
Will Miller
Pixologic Support
