UMM brush malfunction.
Hello all, I habe a strange problem. I’m attempting to do some boolean cuts using an IMM brush. When I first tried it, I’d forgoton to turn on dynamesh so it didn’t work right. I then turned on dynamesh, but now, everytime I try to draw out any shape, with any regular (not curved)IMM shape, it comes out 2d. Completely flat.
The flatness of inserted objects is adjusted with Z Intensity. Make sure Z Intensity is set to 100 for a full sphere, cube etc…
Yeah, I know that usually works. But if I hold alt, then draw it out, it turns flat, and then stays flat.no matter what the intensity is set to.even when I try to draw out normally. I have to restart to get them back to normal
