UI Config
Hey guys, is there a way to store my UI, I mean, with all my custom brushes, alphas, and zmaterials. I store my UI, saved my UI, but every time I close zbrush and open it again, my custom brushes, alphas and stuff are gone, I have to load everything again, and then load my UI, and still get all my custom brushes wrong. I’m tired of this, is there a way to make it work properly??? :mad:
Thanks!
you need to place your custom brushes/alphas etc. into the startup folders - Zbrush doesn’t link to other folders - when you palced them there - then your UI will be the same as you saved it.
Ok, thank you very much, I’ll try it.
Keep in mind that the ZStartup folders are meant only for items you use on a constant basis, so don’t put anymore than 25 items into each folder as you might run into stability problems.
Ok thanks, I won’t then. Just the basic stuff I always use. Thanks!
