UI alphabetize
Is it possible to alphabetize sub pallets in zbrush.
Also, the back ground of the drop down menus are transparent. How can I make the solid so i can read the text on them without being distracted by the model below or other program buttons. I looked under preferences, but I couldn’t find it. Anyone know if it exists or not?
Am I the only one who thinks the people who designed the zbrush UI are out of their minds? Human factors class anyone? :frowning:
Note what I did to my UI. Lots of files posted. (link below my post)
Notice file system structure and naming that I did.
Preferences can be tough to get sorted out(as well as the numerous options)
You can do it by turning on the Subpalette Popup option in the Preferences>Interface sub-palette. This shows only one open sub-palette but when you close it a list of all the sub-palettes is shown in alphabetical order, allowing you to choose which you want. See here, under Sub-Palette Popup:
http://docs.pixologic.com/user-guide/customizing-zbrush/interface-operation/
For the drop-down menus, you can adjust the Popup Opacity slider in the Preferences>IColors sub-palette (it’s the first slider after the swatches). Remember to store the configuration (Shift+Ctrl+i).
Thanks for the help guys. I appreciate it.
I wish pixologic would install an alphabetize button.
To their credit the did install sliders for the popups color and opacity.
hidden under:
preferences > Icolors
I just played around with them and figured out what does what.
