Hey dude, thanks for posting the maps :D… No top row yet!!! ???
Are we gonna see the textured cowgirl??
I’m totally in love with your cowgirl! Very beautiful indeed! small_orange_diamond
Thanx for posting your modeling and rendering process…
I don’t know, why it is not on TOP Row
really awesome
Wonderfull work, they are both great.
Thanx so much for the replies folks…
i did a small making of or u can call it a project overview of the cowgirl.so i wanted to share it with u people.
I started the cowgirl with a simple basemesh ( provided by Marshu Mishu AKA FX81 ) did some minor mesh changes on it to reduse pinches is some areas.
when i was done with that i took the basemesh to zbrush and started sculpting the female body. once i was done with a decent sculpt which i thought was ready to pose, using zbrush transpose tools i posed the body and gave some final touches to the sculpt acc. to the pose. i mainly focued on the curves of her body to make her look hot and sexy.
these r the shots of the workflow.
before i started the sculpt on the head i split it into diff. subtool so as to make things easier and faster to sculpt on.
once i was done with the head i took a cube and started to sculpt hairs on it as as i wanted to try hair scultping in Zbrush.and using subtool master i mirrored and merged the hairs into a single subtool and tweaked it to fit them on her head. herez the process.
after finishing the head and the body.i started to focus on the cloth and leathers she would be wearing. what i did was i took the mid res posed body into max, and made simple base meshes on the areas i need the cloth and leathers,then i imported all those meshes in zbrush and started sculpting them individually as it gave me more freedom to switch on higher sub-div levels.
when i was done with the clothing and leathers, i started doing the hard surface accessories and stuff like that in 3dsmax by importing the midres meshes from zbrush and simply making poly surface on the midres meshes
using polyboost tools .After that it was time to make the guns… which i always hate the most :P. but i made them…
herez some caps of that process.
Finally i merged everything togeather and it was great that zbrush was able to handle so many subtools with high subdiv levels.
For the final touch i used transpose masted to make some final tweaks
to the model to get everything fit nicely.hence this was the final result.
hope u find it useful.
the cowgirl is perfect!!! where can I download that basemesh? are you going to texture her? great work man!
Yee haw. Great job on the cowgirl!
really great work, my favorite part are the boobs, they hang very naturally but are still attractive. They have nice weight.
really great workthrough buddy.inspirational stuff …now i think its time for me to start on a female model.
Fantastic cowgirl model. Great to see the basemesh, and other parts, also.
samar_vijay I have a question regarding your MR shader set up. What material are you starting off with? I see 2 different SSS Fast Skin materials but neither of them have the “Use AO” check box like your. Secondly on the bump shader are you adding a normal bump in the map slot? I cant seem to get the normal map working.
thanks!
Love the cowgirl - brilliant concept but the render with the fighter is ace… only one thing to crit… the feet are in too much of a symmetrical pose on the fighter in that render! Other than that… brilliant.
Jon
Congratulations… for coming on TOP ROW:D
i knew it that ima gonna c this Baby Girl on the top row!.once again great work
I’ve never said anything to anyone about there work.
But that female model you made, made my pee pee move.
GOOD JOB!
You are now a master zbrush master.
May the wacom be with you… always
-peace
WOoooooow nice girl,and nice ass ahhahaahha…
WOW!!!Amazing work!5*
took long enough Amazing works!!
Thanks a lot for share the setups, very usefull!! Lighting texture anatomy… it’s awesome.
Amazing CowGirl!
