Right now the ALT+LMB does three things. It reverses the stroke, it auto-selects subtools, and it frames the mesh. The ALT+LMB should be for reversing your brush stroke only. The ‘auto-select’ shortcut needs to be changed from ALT+LMB to something else and I suggest ALT+SHIFT+LMB. I make folds, clothing, wrinkles. When doing this I use standard brush and lazy stroke. I make and break folds constantly and quickly. In this work flow, I use LMB and ALT+LMB back and forth constantly. If I forget to turn off ‘auto-select’ then the workflow is crippled. I have used zbrush eight hours a day for five or six years. I have already put the ‘auto-select’ button on my UI for easy access. The auto-select should simply be ALT+SHIFT+LMB.
Since ZBrush 4.0 came out we do not need the thin white line around the viewport. The thin white line was originally intended to rotate a mesh by using LMB+drag in the viewport. If the artist, for instance, was working on the tip of the nose of a character and the canvas was no where to be seen in the viewport, the artist could rotate by LMB+drag outside the thin white line. Now, with ZBrush 4.0, the pen stylus can rotate the mesh with hover+RMB. So now the thin white line is obsolete.
Thank you.
