Possibly a stupid question - but assuming I don’t want the heavier hitting Transpose master is there a way to simply nudge a few areas on more than one subtool at once? E.g. I’ve got a model I’m relatively happy with but a day away made me realize the thighs needed widening a bit. And along with it the high boots, the strapping on them and so on.
You could use SubTool Master to temporarily merge the ones you need to adjust together. When done, you can then split them back to their correct SubTools.
If your polygon counts get too high doing that, then you’d want to clone lower level versions and merge those. When done, you can append that merged and adjusted tool to the original, and use Project All on the same subdivision level of each of the affected SubTools to copy the changes across. When you return to the higher level, the changes will propagate across without losing details.
there is a way to do it. but it is the exact same way that transpose master would.
other than that, no.
