I know it’s not the right time to post a question, but I would like to know if you can use AA with TurntablePlus, I tried and instead of rendering it AA it goes to the original Doc size.
Did I miss something?
Thanks
Thanks
It would be useful if you’d say which version of ZBrush you’re using, and also what output options you’re using with Turntable Plus.
Turntable Plus needs to operate at Actual Size (so this is what you’ll see) but images exported will be at AAHalf size if this has been selected before starting the render - so if you’ve saved out an image sequence check those files. However, note that Depth images will be full size.
HTH,
I’m using Zb 3.1 for windows.
My bad, you’re completly right, output files where AA except Zdepth and Alpha.
Thank you.
