1.The active subdiv when selected then that particular subdiv is highlighted,and others are some dull!!!
but for my final output or turntable movie…how can I active my all sub div?
I’ve heard this referred to as “subtool dimming.” I haven’t found a way to disable it. I’ve seen people say that they have an option to disable it in their Preferences pallet, but I don’t have that option (ZB 3.1 PC). Not sure if its something currently only in the Mac version or what the deal is.
What you can do is choose an RGB value and a MatCap then, with MRGB enabled, go to Color>Fill for each subtool. That will eliminate the subtool dimming. It’s kind of a ghetto workaround since there isn’t a simple button to turn subtool dimming on and off, but it works.
2.I make a turntable with turntable plus.but there are some jitter problem in edges,like low quality…but I render this in high qualiy.How can I solve this?
Go to the Document pallet and hit Double. Then go to the side strip and hit AAHalf. This will give you an antialiased canvas which will record more nicely.
