"turn on symetry" won't stay into a custom ui no matter what -- Solved!
Hello folks, I have no problems with the custom ui and I use it happily with all sorts of elements (individual brushes, commands like “replay last” etc). NO problems… except for “turn on/off symetry” that won’t stay in the custom ui.
I put it next to “render” for example, save the ui, store it… restart zbrush, all my changes are there except there is a void where symetry should to be.
It could be voodoo, but my guess is someone who is not a newbie like me has encountered this and found a solution.
Best wishes to all and many thanks for all infos you guys can give me.
It a little thing, but it drives me nuts (plus I want to see when I forgot to turn symetry on!:confused: it’s not easy being green)
Cheers
Usurpator
Which version of ZBrush are you using?
If you’re using ZBrush 4R2, have you installed the plugin from Pixolator that helps with UI issues? You’ll find it in the ZBrush 4R2 FAQ thread, which is a sticky at the top of this forum.
The plugin aurick is referring to is in the very last Q/A in ZBrush 4R2 Troubleshooting FAQ.
MANY MANY thanks Aurik! I had not seen it (I was looking for “ui+turn on symetry”)
I install it at once.
Cheers and thanks a bunch all!!!
U
PS: IT WORKS!!!:+1:small_orange_diamond:+1:small_orange_diamond:+1:
