Troubleshoot - Cntrl + Shift + Click opening Quick Menu
Hi all,
I’m running Zbrush on a remote desktop (PC) through a Mac. I just installed 4R3, and when I try to select a polygroup, the Quick Menu pops up instead. I’m stumped. I don’t know how to select a polygroup.
Please advice.
Thanks!!!
-Andy
Ctrl+Shift+Click should work fine. It could be that the way you’re trying to run ZBrush is encountering some keymapping conflicts, either through the remote desktop software or the Mac portion of the environment. You should have a way to be able to adjust your keymapping but unfortunately I can’t tell you how to do so on your particular combination of platforms.
Thank you. I will look into the key mapping w/ my set up.
-Andy
