Trouble with Ztool Submaster plugin...
The issue I’m having is when I try to merger subtool layers w/ the subtool master. When I merge them the new object scales smaller. I’m not sure what is causing this, any ideas/help?
Do you mean that merging some subtools makes just them smaller (relative to the model) or that the whole model becomes smaller?
Any subtools that I try to merge w/ the SubtoolMaster option end up being scaled down smaller, no matter what settings I use within the Subtool Merge settings.
You might try Transpose Master to fix this issue (it can correct scaling errors):
  1. Load your model and put in Edit mode.
  2. Press the Transpose Master: TPose Mesh button. A low res combined mesh will be created.
  3. Press the Transpose Master: TPose>SubT button. The mesh will be transferred back (though as you won’t have posed the mesh there will be no visible difference).
HTH,
