Trouble with sss render pass
Hi Guys,
I would really appreciate a hand here as I am at a loss. I can’t seem to get an sss pass out of the bp render. I have enabled it in the Render Properties tab but it doesn’t show in the Render Passes. Is there something I have missed. Thank you before hand.
Do the other passes render?(shadow etc?)
OS?
Version of ZBrush?
4r7
I’m using a mac.
yep i get shadow ao etc.
4R7… Any or all of the 3 patches?
last patch. is there a button i am not pushing, it must be something simple as i was able to do it a few weeks ago.
No picture, can’t read your mind or see your UI.
http://docs.pixologic.com/?s=SSS
You also need to turn on SSS in the Light palette>Lights Properties sub-palette for a Light. You should set up the light direction for the SSS you want but note that the light doesn’t need to be on.
