Hi Everyone,
I am having trouble with the Image Plane plugin and tutorial.
Once I use the Projection Master to drop my model and then use
LoadImage from the Image Plane button. This wraps my photo
around my model. I then, after making adjustments, press, “G” the
shortcut to pick up the model from Projection Master. This causes
the texture to disappear! What am I doing wrong??? Help! I’m loosing
too much sleep. Thanks in advance. Eric
you can’t use the FLAT COLOR…any other material works fine.
