whenever I try to append a tool with sub tool only first tool in the list gets appended to current tool,how should I avoid it? if quick pick (the tool box which appears when I click on append) doesn’t have the tool that I want to append what should I do?
after doing a bit sculpting, moving, especially after grouping surfaces, ctrl+Z command just stops working,I can roll back via undo scroll bar but regular undo won’t work, even If i got edit panel the main undo and redo is just grayed out. I can use the ‘tool’ though
