Trouble after transforming appended subtools
Quick problem, i hope
Im appending a sphere to my model to use for an eye. The problem is that after i move and scale it to where i want it, the cursors (the little red dots) get off center from the sub-tool (so that they arent actually touching the sphere when i draw, creating some unsymmetrical effects and making sculpting a challenge). I can get around it by sculpting the pupil and stuff first, but i was wondering if this was a problem of if i had some sort of option enabled to make it do that.
I presume you mean that you lose symmetry after you move it. Turn on Local Symmetry (L.Sym button on right side) if you want the symmetry on the active subtool.
i have symmetry, but its placing my cursor off of the mesh. Ill post a picture when i get home if you need it.
I will also try what you said and see if that changes things
