Trivial question about Zspheres
Does exist a trick for keep Zspheres as result volume?
Say I want this bear for sculpt on it but not the volume that is shown when “A” is pressed!
Maybe it’s trivial but I have forgotten the tip :o
THx by advance :slight_smile:
Bear by FREDKURGHAN
Would you be refering to the ZSphere Tweaks plugin by Mark O’Shea
…does this works for the ZB4?
I have used it in ZB 4 but but only shortly…it does work.
…a little image of the result?
No image. I’m not even sure if this is what your after. Here is link to whole thread and you can check to see if it is what you want.
… I want the same volume that my first image! :slight_smile:
