[Trial Version] ZSphere problems
Hey guys
Im new to Zbrush and have been following the ZClassroom tutorials
I recently started the Zsphere section and have encountered problems mimicking the procedures
Firstly Shift+A does not convert me into the mode allowing me to draw Zspheres
Secondly i am unable to zoom in and out around my model.
I have closed and reopened the program, and have also used the preferences option to revert everything to normal.
Is this fixable or is there some limitation on the trial version?
ZSketch is a ZBrush 3.5 feature. The current trial is ZBrush 3.1.
Other features that won’t be available to you in the trial are surface noise, Quick Sketch, the new hard surface sculpting brushes and Light Box.
Well that sucks, unless i missed it there really should be something warning you that you dont get all the features.
I suppose using the trial as an evaluation before buying it is kind of hard when i can’t use a bunch of features.
Thanks for the help anyway
Everything about the trial clearly states that it’s version 3.1.
It’s very easy to then find out what the differences are between 3.1 and 3.5. In fact, here is a comprehensive list: http://www.pixologic.com/docs/index.php/What’s_New_in_ZBrush_3.5
