Transposemaster Issue [Solved]
Hi there!
I have just encountered a problem using the Transpose master plug-in. When I am finished posing my character and clicking the Tpose>SubT button I get some strange artifacts on my new posed high-res model. It seems like it somehow creases some of the edges from my lowpoly mesh and projects them onto the new high-res model. The model is posed with multiple sub-tools but only the body gets these artifacts, is there any way to avoid this form happening?
Here’s an image of the model before and after the issue occurred.
Thanks!
Asbjørn
So, I just found the solution to the problem. I went back to the high-res model and enabled the smooth modifier, then I returned to the Tpose model and started the Tpose>SubT action. No artifacts!
That’s interesting. I’m glad you solved it and thanks for posting the solution.
