transpose workflow requests:
howdy, doing a lot of zbing at work recently and ran into some issues:
  • the right button will draw out the transpose armature if there is any geometry under your cursor - even if you have rt button mouse navigate on… this means that when i’m inside of a set and i want to place something somewhere precise, i constantly end up redrawing out the transpose armature instead of just adjusting the view so i can place it properly… it would be awesome if there was an option to turn off right button transpose draw… especially if rt button view navigation is on.
  • it’s very very hard to scale something down quickly… if you grab the red end, it only allows you to drag until you get to the white middle, and then you start scaling up again… it would be nice for the red handles on scale to allow you to drag without regard to distance to white middle - only if you were initially dragging toward it or away. you can scale UP quite quickly because you can just pull your pen as far as you want… but if you want to scale down, you have stop when you hit the white middle and then drag again and again and again.
thanks.
jin
